No power output
  • No power output
    On our Bobcat 250NT an employee installed a new battery with the cables in reverse. I discovered and corrected that problem and it cranks up and runs fine. However, there is no power output, weld or a/c and the auto idle isnt working. Ideas on what to check?
    Check the fuses and/or circuit breakers, don't remember what that model has. If they're good, then start with the various diodes that feed power from the battery side to the exciter winding side, exciter rectifiers, etc. If you post your serial number I can pull up a wiring diagram...
