Millermatic 180 stop welding
  • Millermatic 180 stop welding
    It turns on the fan comes on but no wire or weld
    You should post the serial number so the experts can look at the manual/diagrams. Did you look at the troubleshooting section in the manual?
      Does the blue light come on when you're in auto set? If yes, short out the 2 pins for the trigger on the front of the machine.
      Bend a small piece of welding wire and insert. No voltage there, don't worry. If the drive rolls turn it's a gun problem.
      That's where you start.
        First thing to check is circuit CB1 is tripped
          Machine won't power up with CB1 tripped
