can't quite get the metal clean
  • can't quite get the metal clean
    I'm trying to weld the wheel wells back together on my 47 Ford and I'm having a doozy of a time trying to get the metal to clean up. I've been trying a bunch of different ways instead of getting nice shiny metal I'm getting almost a polishing effect. I tried with a new flap wheel, and a braided wire wheel for my angle grinder, but it didn't get much better.
    Pics?
      Do you know what the material is?
        Where the welds are is where I've been grinding. I got some of the edges to clean up but doesn't cleanup to well. The second pic is just on the other side of the bend and cleans up with little effort. I believe it is about 18-20g .
          Stripper disks do a fair job in a situation like that.
            the tacks look like they could use a little more shielding gas sir
            I know rust doesn't help but the centers of the tacks don't look happy and they are all the same
            could be the base matal as you've described, are you using a corded grinder or a cordless?
            a wire wheel should make quick work of that stuff if its a decent corded unit
            the rust isnt too bad judging by the pictures...i mean I don't see daylight through the panel
              Sometimes, when cleaning off heavy mill scale, I find a wire brush won't adequately remove it, and flap wheels just get gummed up. I tried a polycarbonate wheel from harbor freiight and it did a great job. The downside is the wheels don't last long.
                I think it's time for a refill anyways. I'm sure welding overhead doesn't help the situation. I just picked up a new corded grinder. The wire wheel helped in some spots
                  Try a 3m roloc scotch brite disc on an angle grinder. I use them all the time and great for that kind of prep in tight areas too. That metal prep looks terrible, even if just a tack.
                    if you're headed out get a flap disc for the same grinder. sheetmetal won't last very long with a 40 even a 60 grit, I would pick up an 80 if available at the LWS otherwise try a commie-depot
