My 302 trailblazer is producing 120v power for a couple seconds at startup. I tried checking rpms and they will not adjust on the machine display. I adjust the idle and the numbers stay the same. All display lights work. I couldn’t get it to strike an arc even when I have 120v.
Miller 302 trailblazer power problems
All I’ve done is plug a grinder into it and hook up welding leads. When I start it, I tried to get it to arc and it does nothing but it will run a grinder for a few seconds. The display works perfect, I can adjust amperage. I initially thought to check rpms with the machine. It high speeds at 3780 and I can adjust the rpms but the digital display does not change. Basically I take it to idle and the display still shows 3780. I tested the 200 ohm resistor and it showing 196 ohms. It seems to me like it’s losing capacitance but I don’t know what or how to check.
