trailblazer 275 fried boards
  • trailblazer 275 fried boards
    Machine was jumped started. I ordered the power board and the control board for good measure. Is there anything else I need to check before installing the boards? Don't want to fry them again.
    Also, is there a way to check each board? Like a service that will test them? Cheers.
    You are better off to troubleshoot first, then order parts and repair. The tech manual should have pre power checks. You might call millers tech support, they are a great bunch And will help you get it repaired.
      Also might c if the charging system is working. If not that will have to be repaired. I've found sometimes the voltage regulator grounding strap has lost connection because of corrosion buildup.
