Can I use my Co2 regulator on my new Argon tank?
  • Can I use my Co2 regulator on my new Argon tank?
    Hi, I’m learning to do Tig welding and sold my mig millermatic180 For a Miller Diversion 180.
    I exchanged my CO2 mix tank for a pure argon tank.
    I kept my regulator because I’m not sure I could carry it over. It fits but is this ok to reuse? It says Co2/Ar on the regulator which means to me Co2/Argon mix for mig or pure Co2 OR Argon.
    It's for use with argon or an argon mixture. The numbers are calibrated for the Ar/CO2 mix. Pure CO2 can often make them freeze up. I've lost two to that. But you need an adapter to mate them to a CO2 cylinder. So that's your big hint not to bother.
      Great so look like it’s fine for my argon tank.
        Correct.
          These charts may help.
          https://www.concoa.com/cgachart.html
          https://www.concoa.com/docs/catalogs...n%20charts.pdf
