300429 Wireless Foot Pedal not working
  • 300429 Wireless Foot Pedal not working
    I have a Miller wireless foot pedal 300429. The foot pedal is no longer working. I swapped it out with another, and it worked fine. So my question is, can this be repaired? Has anyone dig into the main electronics looking for a fix? I have fresh batteries, and I have continuity on the 3 pin switch inside the foot pedal. Any help is appreciated.
    There is a drive belt inside, likely broken
      Belt drive seems to be fine. I just can’t get it to pair up. Tested it wit another unit, and my 14 pin receiver will link up to a know working g foot pedal.
        Batterys bad, or in wrong maybe
          I did check this. New batteries and installed correctly.
            The box that the batteries go in should have a little contact spring. Make sure it engages the contact correctly...
              Next i would check the potentiometer for correct ohms and also check the switch the electronics in this unit are sadly not repairable.
