Miller bobcat 250Nt
Serial: LC136994
Kohler 20hp motor
Hello,
I have been trying to repair my welder that has a very low output on:
- auxilluary ac when voltage is set to 10
- all weld setting for all polarities
Here is what I've done and tested so far:
Aux. Ac frequency is 60hz at high idle
System does not idle up or down when attempting to weld.
Inspected the brushes they are in good condition and move freely
Polished slip rings to shine
Test F1, F2 and D4 all good
Resistance between slip rings 3.8 ohms
Voltage between slip ring and ground is 13.6vdc
No continuity between slip rings and shaft
Measured resistance of rheostat and cleaned measures from 14 ohms to 0.25 ohms
Measured resistance of large ceramic resistor 4 ohms
Engine sound changes when voltage is turned to 10.
After running with voltage on 10 for about 15 minutes coild smell developed and there was a very small amount of smoke from stator.
Measuring voltage between the lugs I get the following
Polarity, amps, voltage, reading
AC, 100-250, 10, 0.85 VAC
AC, 100-250, 10, 0.49 VAC
AC, 40-100, 10 0.2 VAC
Stick+, 100-250, 10, 14.3 VDC
Stick+,100-250, 5, 8.5VDC
I get sparkles when welding on stick+ and get nothinf while welding on other polarities.
I am at my limit of what I can do to fix this thing. If I can't then it will be the second 250nt I've scrapped in a few months.
Thanks in advance for any suggestions.
