Trailblazer 251 need battery help
  • #31
    Originally posted by Bushytails View Post
    There's an east/west coast split... I'm guessing you're on the east coast? Pretty sure napa is JC like everyone else here on the west coast.
    I just changed my NAPA store to Los Angeles and the batteries still show up as East Penn. I did some reading and it sounds like that split may have gone away a couple of years ago.
    • #32
      Karma, Murphy, whatever you want to call it. I got to start my tractor a little while ago....guess what’s dead. Friggin figures.
      • #33
        The battery that I replaced started the machine twice then nothing. I pulled the caps off and found broken plates in one of the cells. I had to go back and swap it out again because I needed the machine to go to work the next day, so I swapped it out again. Then I went online and did my best to research all the batteries mentioned here. I ended up ordering a Deka AGM battery.. I’ll use this one it other stuff until the warranty period is almost up then return it, as they don’t usually make it 3 years in this heat.
        • #34
          Batteries have come to be one of the most inconsistent products here lately. It would be far less painful if they weren’t so expensive for what you’re getting.
          • #35
            They're expensive because they know you have to get one no matter what they charge you for it...
