1999 Bobcat 225 NT voltage output
  • 1999 Bobcat 225 NT voltage output
    Does anyone know the max CV voltage output for a 1999 (KK model) Bobcat 225 NT? The name plate says max OCV 33 volts, and then it says 20 CV volts. Is that the max output? Or just at 100% duty cycle? I feel like for wire feed welding 20 volts is low.
    Edit: it’s driven by an Onan Permormer 16 (P216).
    CV output range is 17 - 28 volts DC per the specifications table in the manual
      Unless otherwise stated, it tells you a "Rated Output." This is the output they use to give the "rated duty cycle" used for comparisons between machines and advertising purposes.
