Please help - looking for drill press
  • Please help - looking for drill press
    Hello - I've been looking online at drill presses for drilling half inch steel. I'm a bit confused because most of the best rated ones I see are WEN that have a minimum RPM of around 600. I've heard RPM needs to be slow is this not too high? Any help is really appreciated
    Thanks
    depends on the hole diameter. lots of good used ones out there. Location?...Bob
      I have a small benchtop WEN drill press, set at it's slowest speed of 600rpm. If I have to drill anything over 3/8", I use my variable speed mill. Do a search for drill speed charts and you'll see what's recommended for different materials and drill sizes.
        Hougen mag drill.
          The small benchtops run kinda fast for 1/2" holes in steel. I have 3 or 4 of them...Bob
            Unless it’s a small part, it’ll be tricky to get a piece of 1/2” steel drilled nicely on a bench top drill press.
              I've been toying with the idea of going 3 phase motor with VFD so I can set any speed I want on my drill press. My benchtop turns too fast at the slowest speed for thick steel too.
                I bought a 550watt servo sewing machine motor for my 6" lathe. Then i bought an industrial sewing machine and needed a motor so now the lathe sits. They are like $115 on ebay. Speed dial from zero to super fast...Bob
                  550 watts is what, .73 hp? That's not bad.
                  https://www.ebay.com/itm/Industrial-...cAAOSwA3dYWyDY
                  Significantly cheaper than 3 phase and VFD.
                    Yup thats the motor...Bob
                      https://www.northerntool.com/shop/to...9141_200659141
                      That's my next drill press.
                      HTP Pro Pulse 300 MIG
                      HTP Pro Pulse 200 MIG x2
                      HTP Pro Pulse 220 MTS
                      HTP Microcut 875SC
