Mistakes were made
Name:	1911 080 (2).jpg
      Looks like a fun project.
        It is a fun project Ryan. I chose a stainless steel version so that I could perform the changes without needing to replate everytime I made a change (or mistake)
          That looks awesome! How did you get back to the original finish on the frame?
            Good thinking.
            Looks like you’re doing a really good job with it. There’s a guy on YouTube called mosinvirus that has several part videos on the 1911s he’s made. He does a really good job.
            • #21
              The first revision (pictured) was sand blasted using a more aggressive media that appeared really dark. The second revision (not pictured) I changed to a finer media and it lightened up the finish a lot. When I say aggressive I mean aggressive in relation to the finer end of the scale. I'm currently working on a separate project that will be ceramic coated and the required grit for that application is around 200.
              To answer your question directly, I will sandblast the frame and slide taping/masking the flats of the slide. They will be finished to 1500 grit and then roughed out to a medium grit hand pad (scotch brite) for a straight and consistent grained finish.
              I plan to use 200 grit media to refinish this pistol to see what it looks like as a test. If I don't like it I will try a different grit.
              The ceramic coating I will be using is Cerekote. It's some seriously badass **** for those that don't know.
              • #22
                Originally posted by ryanjones2150 View Post
                Good thinking.
                If gun smithing were welding with car batteries and coat hangers
                CABOT GUNS would be tungsten inert gas welding 6al4v upside down with a mirror in zero gravity with both eyes closed
                If you haven't seen "the big bang" I would suggest taking a close look at them.
                • #23
                  Holy......
                  ....wow.
                  • #24
                    Turned more slide material into chips today. I'm getting tired of the dovetails and the fitment of the sights. I might be at a point someday where I'll build up weld at both ends of the slide and machine billet sights on the darned thing...wrong forum for this, I'll stop now.
Name:	Front Serrations 1911.jpg
Name:	Re-cut Front 1911.jpg
ID:	606127Click image for larger version
Name:	Drill Front Sight 1911.jpg
                    • #25
                      You could one-up Cabot and make it out of unobtanium or nonexistium, but they’ve probably already done that too.
