Maxstar 200 Won’t Weld
  • Maxstar 200 Won’t Weld
    Hey guys I have a maxstar 200 sd. I bought it second hand and it worked great the first day. Next day I plugged it in and went to weld but won’t strike and arch. All settings and functions work voltage reads 12v but as soon as you make contact with your work piece it drops to 0. Any ideas what this issue could be?? Thanks
    What are your parameter settings and process? Have you tried other processes (stick vs Tig) and/or parameters (scratch, lift, HF)? Without VRD set (I haven't messed too much with a Maxstar 200SD, but assume 12V is the VRD output for stick)?
      Did anything else change? Such as maybe using a different power outlet, etc.
