MIG welding stainless steel
  • MIG welding stainless steel
    I picked up a piece of stainless steel to practice with. I don't intend to do much with stainless but decided to try it. I've always heard a tri-mix gas is best and 75/25(which is what I used) leaves a lot of spatter. I didn't see much spatter but the brown stuff is what I didn't expect. I did brush it as best I could but would the correct gas still leave this brown color behind?
    C25 doesn’t cause an increase in spatter in my experience, but the soot is from using the C25.
      Originally posted by breavis View Post
      ... I've always heard a tri-mix gas is best and 75/25(which is what I used) leaves a lot of spatter. I didn't see much spatter but the brown stuff is what I didn't expect. I did brush it as best I could but would the correct gas still leave this brown color behind?
      Where have you always heard that? It's well-documented that it's not a spatter issue, but a contamination issue from having CO2 in the shielding gas.
        Heard that on another forum. Thanks for the info
