Miller AEAD 200LE - upgrade taper terminal connectors to tweco?
  • Miller AEAD 200LE - upgrade taper terminal connectors to tweco?
    i have a 1980 Miller AEAD-200LE with a serial number of JA453900, the unit runs great and it is a joy to have save for one thing...the taper connectors for the leads.
    has anyone ever tried to swap out the taper terminal connectors to something like a tweco or dinse? all of my welding leads are tweco and i have to keep separate cables to connect to this unit; it would be great to get everything using the same connections.
    in looking at the taper terminals it looks like they are just bolted up with 2 nuts behind the faceplate.
    was wondering if i could just put a bolt and nut through and connect something like this: https://www.amazon.com/Tweco-Arcair-.../dp/B0029ZVSAK
    anyone ever seen this done? maybe it is not worth it?
    I'm thinking there may be a bit more to fitting out the connection.
    https://www.manualslib.com/manual/46...page=60#manual
      i have an older model from 1980, parts schematic here: https://www.millerwelds.com/files/ow...MIL.pdf#page38
        Riverweldstore on ebay has hundreds of components including panel connectors at reasonable price.
