Hello I’m new to the forum
  • Hello I’m new to the forum
    Trying to find engine serial # and I found a number on front of panel I don’t know if that for the welder. Need help !!
    thanks
    caesar morales
    My photos didn’t load
      I bought a Miller roughneck the number on front of panel HK257319
      thanks
      caesar
        Welcome, yup thats it
          If you go HERE you can search for your manual, I didn't find one with the number you provided, however on the same page you can search by the model (roughneck) name
          Richard
          West coast of Florida
            Here are some photos of my welder I got today!!
              Welcome to Miller's website and good luck with your welder, I had two Miller Electric Legend AEAD-200LE machines, both were great welders, it will serve you well. If you plan on welding 50' or more away from the machine buy the largest leads you can for it, and a quality ground clamp, and rod holder.
                1, remove blue cover and inspect innards carefully.
                Pay particular attention to potentially loose windings before starting engine.
                repair loose windings
                2 clean dust, dirt, mouse and bug nests from machine
                Do NOT use compressed air above 20psi or a pressure washer to accomplish this.
                While cleaning also clean ut Kohler air plenum & head fins
                3, check oil level and cleanliness in Kohler
                Replace if necessary
                4, remove spark plug and put a teaspoon of Marvel Mystery Oil into the cylinder above piston
                Rotate slowly by hand to distribute oil
                5, install new spark plug gapped .025" unless Kohler has coil automotive ignition.
                Verify spark
                6 Fight with fuel system
                Hint, new replacement carbs are currently on ebay around 20 bucks. They are much better than rebuilding the old carb.
                  Thank you !!
