Threshold ramp
  • #31
    FLAG ON THE PLAY -HOLD ON TAKS END
    You struck something brown, sticky and smelly.
    1- the actuator can be hadfor under $20- ebay
    2- the controller you fund won't handle the current the actuator requires, it will COOK
    3- there is already a perfect radio controller to perform the function and handle the current- It's called a 12 volt winch controller.
    4- only thing left to process is the power supply
    I'm thinking 12 volt computer supply acting as a charger on a sufficient size battery.
    If you add slightly to battery capacity you can also have12 volt emergency backup lighting very cheap using LEDs.
    • #32
      Here you go Tack, somebody already put the kit together for you.
      https://www.ebay.com/itm/Heavy-Duty-...f1fe12ff567b11
      I'm thinking 10" but do some tape measure reading first.
      • #33
        I'm going to open the door as far as it goes with the closer on it and measure the whole unit at it's longest travel, I still want to mount it on the top of the door, I can buy a fiberglass battery box and put a car battery in it, slip it under the ramp and hook a trickel charger to the battery, how does that plan sound to you Franz? Thanks for finding the actuator for me, Ill get it measured and ordered tomorrow.
        • #34
          I use genuine Chinee 2 amp computer pwer supplies for that, set the voltage about 13.4 and they play nice with batterrys. The one in my Exploder that runs thewindow fan is a GT battery with a 2 amp I added a fan and digital voltmeter to. Nothing gets hot, and people just gotta ask abut the voltmeter so I can tell them it's critical to know battery voltage. Lot of entertainment fora buck voltmeter.
          Fiberglass box Neh, Wally has tupperware boxes that are heavier for lless $$.
          Just one thing Tack, from now on you gotta remember as you roar downhill toward that door to push the button and eyeball for open. Hate to think of pealing a door off your carcass.
          • #35
            I like your Idea of a Tupperware box, it would allow me to rap the battery with a heating pad and line the box with hard foam insulation, along with placing a trickle charger and a thermostat I have in the box to turn the heating pad on and off.
            • #36
              Tack, right idea (or at least ONE of 'em) but WRONG actuator - do you REALLY wanna wait a full MINUTE for that door to swing open or closed? There are actuators that move anywhere from slower than that, to 'WAY faster - I found some that would move your door full swing in about 5-6 seconds, much faster than that would probably damage some hardware. Slower than maybe 6-8 seconds full stroke would drive me (even MORE) crazy... Steve
              Oh, also - over 300 POUNDS of force? Rod almost an INCH in diameter? You building a screen door closer or a DUMP TRUCK???
              • #37
                I'll do some searching and see what I find, thanks for the info,BC.
                • #38
                  Before you order anything I suggest you grab a few paint stirr sticks and some screws and model the idea up on the bench.
