I’ve always called this issue burn back, miller seems to call it something else. Basically my wire is hunting and pecking in the puddle. It will hit and burn back halfway to the contact tip and hit again. I can control it fine if i turn autoset off and manually adjust the wire feed speed.
My question is if this is common on Miller Autoset? Do people have feed issues with the wire not staying an even distance from the puddle and burning back?
My drive roller is not slipping. It’s been ran everywhere from loose to nearly crushing just to be sure that is not my issue. It feeds perfectly and is currently set to where it barely slips under high tension (right before it would birds nest).
Is this how Autoset normally behaves?
