If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You may have to register
before you can post: click the register link above to proceed. To start viewing messages,
select the forum that you want to visit from the selection below.
as for the portacable porta band saw not shoure they make 1 of the 2 milwaukee i would see it you can tell if 1 of them can be atached to a base, i know they make a version that will base mount giving you the best of bolth worlds, base and portable maybe someone here can get ya some modle #'s to compare with
Pick up a almost new 6 amp sawzall and two packages (5 each) of some Milwaukee bi-metal blades in a nice handmade oak case at an auction Saturday for $55. Used it yesterday for the first time - tis very nice. My next purchase will be the portaband. The Northern Catalog (used for benchmarking) shows two differant Milwaukee portabands, one with a case and the other is a two speed (with or without case, I dunno..). Basically similar in price. Not sure which is better. Where I can find the porta-cable to compare? Thanks for all the help!
Lord, it's going to be another hot one today... 95+ & 99.9999% humidity.
I agree with fun. I have a porta-band and a sawsall. My first choise usually is the porta-band but it can be bulky and just won't fit in some spaces. The sawsall would be my choice if I could only have one. Also they are about 1/3 the price of a porta-band.
joebass
they are 2 totaly different tools you cant compare they bolth have different aplications and he already said he could not use 1 as it would not fit between the bars. kind of an appels and oranges thing they bolth will make juce but in different manners
I have never used anything other than bi-metal blades (Dewalt and Milwaukie). You can get them in a hack-saw blade type with the varying off set but don't remember what the tpi is but likely 18-24 tpi range. One thing I do not do is to use the saw rest/stop against the work but free hand it. If you are steady and use a light pressure you won't have a problem.
i use Morse bi-metal blades 14teeth per inch. I think most blades are about the same, i use Morse because i got 150 of then for $40.00 off e-bay. if you look and watch for a wile you can get some sweet deals. it took me about 2weeks to get a large batch within my $$$$ cash range but it realy is nice to have a bunch around and not get caut short in the middle, not to mention $0.26 each is prity hard to beat . i was trying for a wile to get just Milwaulkee or dewalt blades but they are harder to find in big enough quantitys to be afordable . the sawsal is a great tool and sees alot of use in my shop as it is quick and can be real acurat or atleast close enough that a sanding disk can finish it off . i have 3 a milwaukee, a dewalt and a portacable. my milwaukee is the oldest about 15 years old and the portacable and dewalt are bolth about 2 or 3 years old. the portacable being my favorate they realy are a verry versatal cutter. i have even used mine to trim some of the larger limbs off the trees
a bycicle hanging hook from walmart will alow you to hang them up where they are handy and out of the way (see pic)
I concur with fun4now about the saw. I have cut 2", 3/16 sq tube with a DeWalt variable speed sawzall accurately and cleanly free hand as well as cast iron 3" pipe. It will cut faster if not just as fast than the portable plasma.
3/16 square tubing is not going to be verry good at, a nice saw sall would be the ticket. as for the 1/8" it will do nicely. but on the 3/16 you will have a lot more cleanup if looking to reinstall a new rail. a sawsall would cut smooth and strait along the bottem/top rail and leave it ready for a new 1 to be welded in.
i realy like my 125 but would use my sawsal first in your aplication.
as for precision work on up to 10gage it is sweet (see pic)
yes... it'll work IF you take it VERY slow and easy and your tip is in decent shape... 3/16 is toward the max side of this unit. I only use my 125 for precision work. Most of my cutting with it is with 10, 16 or 18 gauge etc. Have a very nice O2/fuel torch for the larger stuff. If 3/16 or larger is a majority of your work and/or, you're in a hurry - I would recommend a larger unit. I am happy with mine as-is due to my application(s).
1/8 to 3/16 square tubing is what i would be cutting and a unit with its own compresser is what I'm looking for so i don't have to lug around a compresser
