Franz, who makes the best Jewish welding wieners
    Originally posted by Burnt hands View Post
    ... puts the dogs across the AC line and would cook 6 dogs in 60 seconds.
    We made our own version using a zip cord and two banana plugs for the electrodes.
    Cooked up (and ate) about 8 before someone noticed the brass under the banana plug plating was showing.
    The plating was being electroplated into the hot dogs.
    This put a quick end to our experiment.
    I used stainless steel screws.
      Probably direct from the BLM stock room.
      Did you sweet talk the little electrician into getting you a pulser for the circuit? If not a 60 watt bulb in series will give you slower cooking and more even heating.
          Originally posted by Franz© View Post
          Probably direct from the BLM stock room...
          BOR! I knew your memory was going...
            All your fault, cause you wouldn't get me down into the water impoundment structure when I could still hobble good enough to climb back up.
            Only thing got reclaimed when you were at the D am was a pocket full of screws belonging to taxpayers. Good thing the little woman wired em up for you.
            • #21
              Trying out some Karbach Crawford Bock injected directly into the brats after they went for a swim in it. Mesquite/Pecan/Hickory Tri-Mix.
              HTP Pro Pulse 300 MIG
              HTP Pro Pulse 200 MIG x2
              HTP Pro Pulse 220 MTS
              HTP Microcut 875SC
              • #22
                Success!
                Using as authentic of a German mustard that is available around here. Love it. Although I do have to confess, I like my bratwurst with a little bit of ketchup.
                HTP Microcut 875SC
                • #23
                  BAH! No brats for you!!
                  Ketchup? You blasphemer.
                  • #24
                    I gotta look at the map but I think he's South of the line where Brats can be sold and consumed.
                    • #25
                      Had these over the weekend in homemade tater soup, they were delicious. https://eckrich.com/products/smoked-...skinless-rope/
                      • #26
                        When you make tater soup avoid them Yukon Gold taters. They're good mashed and fried especially with some garlic & onion in the case of fried, but they ain't good in soup.
                        • #27
                          Franz the daughter used russets for the soup, it was wonderful soup, I told her next time to put in chives and fry up some crispy bacon and chop it up and put it in the soup too.
                          6 tablespoons of butter
                          2 cups chicken broth
                          2 cups of water
                          9 russet potatoes
                          1 cup of whipping cream, 1 1/4 cup of milk
                          3 stalks of celery
                          1 onion
                          3/4 cup of shredded Colby Jack cheese
                          2 lengths Eckrich 4 pepper sausage.
                          Essentially every thing to taste.
                          • #28
                            Should we have an "off topic" section?
                            J.Caraher
                            Wide Open Throttle Technologies (WOT-Tech), Pompano Beach FL
                            Miller Sync 300,Hobart 190
                            RogueFab pneumatic, Hossfeld Manual
                            Kitamura CNC, Bridgeport 2j
                            TunerPRO, HPTuners, AEM, Megasquirt, DynoJet
                            NASA Racing Official/Driver
                            YouTube Link, Instagram Link, FaceBook Link
                            • #29
                              I'd have scrapped the water and replaced it with chicken broth.
                              Add about 2 cups of shaved leeks sweated in butter with the onions.
                              Actually you're making sort of a small batch there, we load in a couple of them 2 quart boxes of broth when we do it up.
                              Last step, oddly MY job so I can be blamed for any splashing is the Oster hand blender outboard motor.
                              When I do it correctly the onions and leeks sit on the bottom as everything else gets properly homogenized and incorporated.
                              What's left goes to the freezer, heavy plastic bag inserted into the broth box after the box gets washed out.
                              • #30
                                Onions used in excess makes one breath stinky. Rather inhale galvy welding dust to be honest.
                                Used sparingly, diced sweet onion helps the seven bean chili to sweet, but be sure to use at leas a cap full of apple vinegar to keep the later gaseous activities to a minimum.
                                J.Caraher
