Welding after cataract surgery
    Originally posted by ryanjones2150 View Post
    No I don’t either.
    Do too, that's why you won't use a LED flashlight.
    You got a bunch of Department D cells stuffed in paper towel tubes taped up powering the footstink exhaust in that teardrop trailer.
      Nope. Maybe firemen up in your part of town are thieves, but down here, our integrity is paramount. I, in fact, have purchased batteries for our lights and even batteries for people’s smoke detectors when our supply chain was confused as to who are sworn duty to serve is intended for.
        You swiped my Clark bar.
        You've admitted swiping my Clark bar
        What kind of integrity is swiping an old man's Clark bar?
          I did you a favor. In Canadian, that’s “favour”.
          You’re welcome.
            And if I buy that claim the next thing you'll try promoting is how you only swiped Bob's welding ladder cause the Department needed a ladder and couldn't afford to buy a ladder.
            I'm picking up a definite pattern to your nefarious conduct.
            • #21
              No cataracts, but My eye aren't so good. I have a Jackson truesite lens in my hood super clear. I wear contacts that give good distance but need cheaters to read. At work we get 3M Nuvo bi-focal safety glassesI. I use 2.5's to weld and can see ok. Can't do sanitary pipe anymore though just can't see the seam. But still able to do all other welding. Certified pipe (TIG). I've done the cheaters in the hood those work nicely but with Bi-focal don't need the cheaters. TIGing on small stuff I'll trun the shade down to 10 sometimes 9. Welding flux-core back up to 11.
              • #22
                Sound like most of us then. Reminds me I should get my eyes checked?
                • #23
                  Here's my update. I tried the red (or gold) lens in my old helmet. Might have been slightly more clear but not enough for me to give up my auto darkening hood. I have been using one of those for probably 25 years and can't go "backwards" now.
                  I then got some magnifier lens for my Miller Digital Elite hood. I tried both 2x and 2.25x. Here is what I have found.
                  For one, I need my bifocals on so I can see where to weld, then when the hood goes dark I need more magnification. So for me a 2x bifocal and a 2x cheater lens works fairly well. As I stated in my first post, the brighter the light is (doesn't matter if it's from the arc for from exterior lights the better.
                  With these lens in my eyes, the trouble is, the more light I have the better I can see. In bright light I can read most print. The darker it gets the more magnification that I need.
                  So what I really need is a magnifier lens in my helmet that adds more magnification the darker it gets
                  I am going to try this for awhile and if not happy I will break down and buy the new Clear Light autodarkening lens for my helmet
                  If you are interested in antique tractors https://antiquetractorblogger.blogspot.com
                  • #24
                    I have, in the past, been welding in a dark corner of a project. I’ve used all sorts of ways to illuminate the work. Sometimes “playing the arc” just doesn’t keep me on track. I have work lights with hooks, straps, magnets, etc. I’ve even taken a flashlight and duct taped it so it shines down the length of the joint from the direction I’m traveling in. It actually worked really well. Gave just enough light to see the gap ahead of my nozzle.
                    • #25
                      More as a matter of curiosity than anything else, when did you last change the batterys in your autodark? My experience with the LI cells is their performance curve causes the helmet lense to stay darker than it is set for as the age of the LI cell increases.
                      Second possible solution is to add a couple of the newer LED cobb strips onto the face of the helmet itself with a 3 cell LI battery attached to the helmet. 8600 series LI batterys should yield a few hours of illumination. The new cobb strips are about half an inch wide and 2" long, and deliver light rich in the UV spectrum, around 6000k. Fortunately they are cheap enough to experiment with, under a buck each.
                      • #26
                        I changed the batteries in it in the last year or two. I wasn't aware that battery voltage would cause that but it's an easy thing to try.
                        Is this what you are referrring too for a cobb light? https://www.amazon.com/Universal-Wat...ateway&sr=8-13
                        I have the LED light on my helmet now but more light would be better. The main advantage to my head lamp is I can aim it directly at the weld
                        • #27
                          I bought some LED lights on a tripod stand so I will have to start using that too
                          • #28
                            Good and interesting info on the batteries aging--I never really thought about that, but it makes a lot of sense, and now that you mention it, I've seen that in LED flashlights and area lights.
                            • #29
                              To put it mildly the instant discussion is getting a whole lot more complecatedered-esumtin than originally envisioned.
                              Buds of mine who put groceries on the table by slaving in air conditioned comfort for B&L, quite probably the company that made your eyeball2.6 replacement lense as well as half of the equipment to do the job have been volunteered to get me inside B&L so I can see what they are talking about and sketching. Seems there is a bit more to lense tech than I remember from years passed.
                              As I currently sit here, I am now aware of a situation the lense sketchers call "diopter clash" which I am pretty sure is a matter of mismatched focal lengths causing multiple lenses to become non additive as happens in prismatic binoculars or rifle scopes when an element becomes dislocated for simplicity of explanation. There is also possibility of other visual distortions entering the chain of image amplification caused by less than perfect element alignment.
                              Quick and dirty- a single lense of proper power will usually give better results than multiple lenses attempting additive amplification.
                              Second issue- COB illuminators.
                              They just keep getting better and delivering more bang for the buck- quick and dirty comparison indicates Amazon sellers are a year behind state of the art and ebay from China direct is selling much closer to state of the art.
                              I'm in the process of changing out kitchen cabinet internal illumination I installed 4 years ago - new illuminators are 10 times better.
                              I haven't really had time to evaluate LED
                              on the front ofa helmet acting as task lighting. One thing I am sure of is that the higher Kelvin number the better it works on steel and seeing cat hairs on the floor. LED is now on the market that is approaching 6000 K and that range works well for me, it may differ for others.
                              https://www.ebay.com/itm/LED-COB-Chi...72.m2749.l2649 is a really nice COB emitter for attachment to a helmet. ADD HEAT SINKING
                              These are a better choice for area lighting and are 120 volt AC units.
                              BOTH are bright enough you do NOT want to look directly into them. Both require additional heat sinking with heat paste conection and both can be destroyed by improper soldering technique.
                              • #30
                                Thanks for the links.
                                My left eye has astigmatism so had to get a different lens. Left eye got an Alcon Arysof Aspheric UV absorbing ReSTOR +2.5D multifocal TORIC lens Model SA25T5. Recommend for patients who require more intermediate (21") and distance (13') vision https://p.widencdn.net/v2a8te/W40-50...S_Restor_Toric
                                Right eye got a Tecnis Multifocal lOL +3.25D for enhanced performance at 16 1/2" Outstanding, Full-Range Vision Tailored for Longer Reading Distances
                                https://www.jnjvisionpro.com/product...ocal-iol-325-d
                                I assume because I am younger (57) he gave me lens for intermediate vision vs close up. If I test the eyes individually the right one does better at reading fine print. Left one is better at computer work though both together are better than just one. Cheap 1.75x magnifiers make computer work way easier though.
                                I have several older friends that got one eye for distance and one for close up stuff. Both are happy and don't wear glasses at all. If I knew what I knew now that might have been the best option. Having said that I don't know how those lens would work when welding. I am a farmer not welder so I don't weld for a living but when I weld something it needs to look good as well as be strong thus my frustration with my new eyeballs.
