I have 2 inch 1/4 inch thick aluminum square tubing I need to cut. I want to get a saw but dont know which one. What works better for cutting aluminum a circular saw or miter saw?
Circular saw vs miter saw for aluminum
Assuming you have the proper blade and the saw spins the blade at the appropriate RPM, both saws should yield an acceptable quality of cut. A mitre saw is typically a more flexible version of a circular saw itself would be able to tilt one or both ways clockwise/counterclockwise in addition to turning left-right on the base.HTP Invertig221 D.V. Water-cooled
HTP Pro Pulse 300 MIG
HTP Pro Pulse 200 MIG x2
HTP Pro Pulse 220 MTS
HTP Microcut 875SC
I have a dewalt miter saw that cuts aluminum 95% of the time. It’s cut way more aluminum than wood, I can tell you that. Still has the blade that came on it. The chips don’t feel good on your skin when you use it, so I use a face shield when I cut.
And ear plugs.
I also have a table saw with the same history. You don’t need a special blade, just keep an eye on the teeth as sometimes they load up with aluminum schmoo.
- Likes 1
My preference goes to worm drive saws in the hand held category and overarm type saws in stationary setups.
Table saws can and generally will get inexperienced operators into trouble fast if the sheet starts hopping on the table. A sheet of aluminum coming back at you in Warp Drive hurts.
Whatever saw you choose, be absolutely sure what you're cutting will remain firmly attached to the table until you finish cutting.
Waxing the blade is always a good move too and tends to extend blade life.
Everybody has there favorite chop saw...........for me it's this Evolution w/ a 15" carbide blade which makes easy work out of aluminum, mild steel , Chrome Moly , plastic , ETC.......you name it......have to be careful with the razor sharp chips it spits out.......but a small price to pay for the overall performance...........slow rpm.... 2 years on the same blade.....store it under the cart when done, will cut 45's and compound miters if you have a fixture to hold the material.
Originally posted by Franz© View PostMy preference goes to worm drive saws in the hand held category and overarm type saws in stationary setups.
Table saws can and generally will get inexperienced operators into trouble fast if the sheet starts hopping on the table. A sheet of aluminum coming back at you in Warp Drive hurts..
Originally posted by tarry99 View PostEverybody has there favorite chop saw...........for me it's this Evolution w/ a 15" carbide blade which makes easy work out of aluminum, mild steel , Chrome Moly , plastic , ETC.......you name it......have to be careful with the razor sharp chips it spits out.......but a small price to pay for the overall performance...........slow rpm.... 2 years on the same blade.....store it under the cart when done, will cut 45's and compound miters if you have a fixture to hold the material. [ATTACH=JSON]{"data-align":"none","data-size":"large","data-attachmentid":599859**[/ATTACH]
At my school we bought one of the smaller Rage 3 10" saws for their solar car project and it's worked great for them. It has a double bevel on the saw support for ±45° clockwise/counterclockwise, and the base has it's own swivel for miter cuts as well.
About $350 or so. They also have a R255SMS which only has a single bevel, and of course cuts miters.Last edited by OscarJr; 07-22-2019, 07:32 PM.HTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
Originally posted by OscarJr View Post
Ooohhhh, the EVO Saw380. I want that puppy! I have the cheapo Rage 14" with the multipurpose blade, and it serves well for what it is, but I'm sure that EVOSAW 380 is a beast with a good blade on it!
Ya know it really does work well to cut through even big pieces of steel bar stock ,structural shapes , plate or aluminum ...if it fits it cuts!......the key is just light pressure on the blade and let it "eat"........noisy yes....and the chips......so ear , eye protection and a long sleeve shirt is a must and be persistent to broom the floor after making a mess.....comes with a 14" blade but the 15" is a must............I still love it!HTP Invertig221 D.V. Water-cooled
HTP Microcut 875SC
You guys with the Evil saws need to hunt up Strawberry U's world famed chopsaw housing made from an old basement oil tank. Maybe he can find the picture where he left it (NOT the MardiGras pics Carey) and post it here.
He really outdid himself on that project. Of course he was single then and had more shop time.
How many thumbs are still attached Heli?
