I have a 1950's Ford disc that I use for yard and garden work. It's heavy enough to do pretty much what I want it to. However it broke last year with disastrous results. The angle bracket which held the three point pin cracked and failed, and the disc swung so that the discs shredded the calcium filled turf tire. I replaced both tires, as I had bought spares back in the 80's when I bought the tractor. Now it's time to repair the disc and put it back to work.
The break was from fatigue at the corner of the angle bracket holding the pin in place.
I admit that I am a bit concerned about a similar failure, and taking out calcium filled (or worse) tires.
My plan is to replace a segment of angle bracket which is welded to the disc frame, by grinding off the old, and welding on a new piece. I don't have quite the same size material yet. I thought it would be better to use new material than repair the existing.
What I am trying to figure out is how, rather than simply using heavier material, to prevent a similar failure, with perhaps a redundant structure.
That's an idea, but I don't have allot of experience fixing things like this, and no experience creating redundant structures. Any pointers or ideas?
