Dynasty 200SD low buss voltage
  • jjohn76
    I just talked with Dan at Miller Tech, who confirmed that 12V is correct for the negative rail for the hall device and the boost IGBT (Pin 8 on RC1 for PC2 and PC10). I am definitely writing this down in my manual on the PC2 and PC10 checks.
  • jjohn76
    Getting PC2 ready to replace the relay, I found a couple hot spots on the board (resistors that look to be a part of the control transformer switching circuit). Does this happen often? I need to draw out that circuit, but believe the resistors and capacitors are a snubber circuit for that IGBT on the heatsink in the center of the second photo.
  • jjohn76
    Yes, I know my wife won't allow me to commit that kind of time to this project, not even going to ask... I forgot to mention I get my technical manuals from eBay, and the seller just happened to have them for this model and my Dynasty DX. He only sells printed copies, it would be nice to get them in PDF files though. I think I am going to replace those zener diodes. 11.4V and 9.8V are a little too far off spec for 12V and 10V zener diodes, though it may lead me to the real problem if it doesn't work. The board isn't pulling less than 100mA from a 30V input, so I don't expect a component drawing heavy current anywhere.
    Thank you!
    Jon
  • Aeronca41
    Yes--possible something is missing there. I looked up the element14 site--that guy is astounding! Makes me want to go in and haywire a fuse into the VR4 circuit on mine! It won't be in the next couple of days, but I will also measure R86 and send the numbers to him.
  • jjohn76
    Thank you Aeronica. It took a little while to trace it out, but I only did a small part of that board. I came across a thread on an element14.com website where a member rebuilt the entire board, schematic, PCB and all. Now that guy has some serious patience! The buddy that brought the Dynasty over has helped me out on a lot of things, so I didn't mind putting in the effort on an obsolete board. Radwell advertises to rebuild them in case I can't get an answer. The guy took it to a Miller tech shop up here in Washington who gave it a clean bill before it wouldn't power up, so he's looking for another tech shop for his other Miller welders. I think I need to recheck my schematic, something about the inputs to that NAND gate Schmidt trigger at the bottom doesn't make sense to me. That Schmidt trigger seems to me what drives the gate signals for the buck-boost IGBT.
  • Aeronca41
    First, let me say I'm impressed with your patience and diligence! I don't know if I would have been patient enough to trace all that out! I've done it in years gone by (many years gone by actually) but WOW!
    Hopefully one of the Miller techs will see this thread and be able to help. You might also call them with this info and see what they say--probably "Take it to an authorized service center" but it never hurts to ask. In my experience they have been very helpful. Pretty cool that you at least have a tech manual--I have a blue lightning 200DX and have been looking for a tech manual for several years.
  • jjohn76
    A follow-up, I worked out most of the buck-boost circuit on the attached schematic. It looks like the reference voltage comes from D8, which is a 1N4742A (12V zener diode). I think I am missing something or the technical manual should show -12V for Pin 8 on RC1. Someday I will get a schematic program loaded to make these easier to follow.
  • jjohn76
    started a topic Dynasty 200SD low buss voltage
    Hi, a buddy brought his Dynasty 200SD, SN LE151928, because the front panel wouldn't light up. After going through the pre-power checks, I powered it up and found the buss voltage is only 325VDC. So I checked out the boost board, PC10, Assembly 200841.
    The only issue I found on the board is -12V instead of -15V (tech manual ref value) on Pin 8 of RC1. It is EXACTLY -12V which makes me wonder if it should be -12V. It's also a clean voltage, with very little ripple. Has anyone else seen this on their board? It powers the boost circuit current sense (HD1 on andPC2) and negative bias for off switching on boost IGBT, so I don't really want to power it up without verifying this voltage first.
    I also found the input relay on PC2 was fried (back left corner, picture below) which wasn't linking the boost inductor circuit to the main lines. For those who have a buss voltage of only 325V, this could also be the issue. To check it, I pulled PC10 and put 24V across Pin 5 and Pin 6 on connector RC10, making sure I heard the relay click. I checked the resistance across Pin 12,RC1 and L_Input on PC2. Mine read 200 ohms, which means the relay didn't close. Hopefully this saves someone some time down the road...
