Hey guys-
I just picked up a 330 a b/p to replace my old(er) Dialarc and am working on getting it all set up. I wired everything in, set up the torch, ground, etc & fired it up. HF was in the “start” position and it fired up as it should, & quit when I struck an arc. After working once on that initial test, the HF won’t kick on at all under any settings. The caps were leaking some so I replaced them with “known good” caps (same exact model from a machine with functioning HF) and nothing changed at all. Still no HF in start or continuous, ac or dc. Is there something else (fuse etc) in that circuit I could’ve fried after that first initial test? Something else I don’t know about?
Thanks in advance!
Thanks in advance!
