Originally posted by Solid Lifters
View Post
This tells me you have to readjust your thinking. What will happen when adjusting WFS is the amount of wire will increase or decrease. The power source is Constant Voltage. Amperage varies. The biggest variable is wire stick out and which voltage tap your set on.
Increasing the WFS will result in a greater amount of wire exiting the gun, a narrowing of the arc, an increase in deposition, and the droplets being firmer and more forceful.
Are you using the same size tip or one slightly larger of a tip then wire size? Is the tip recessed, flush or extended? Bumping the WFS should help with burn back as well as using a longer stick out.Increasing the WFS will result in a greater amount of wire exiting the gun, a narrowing of the arc, an increase in deposition, and the droplets being firmer and more forceful.
Post a picture and good luck.
