I've had Miller stuff for over 30 years and would still weld my mild steel projects with an old Miller Matic 10 if I'd get busy and replace the sockets and cables. So I got froggy about 15 years ago, mostly because my business partner wanted a new 250X at company expense, so I thought I'd upgrade mine too. I found the 250X to be MUCH MORE complex and much less forgiving than the old machine and continued to use the old one for mild steel. So being retired now I figured I'd learn to use the spool gun that came factory installed in the other machine. This machine is probably the oldest new one in the world, due to the fact that just as a hobbyist for the last 20 yrs or so it basically sat in the corner while I used the older/simpler one. Trying to learn to use the spool welding aluminum has been nothing short of a nightmare and I'm at the point of not knowing whether to get my 25 lb sledge hammer out and beat the machine into scrap metal or simply roll it off the end of my dock into about 10' of water and forget it. Frustration doesn't begin to describe my present feeling. I'm trying to do simple welds on 1/8" NEW aluminum, cleaned with a stainless brush. With the internet information recommending wire speed and voltage it's easy to find a recommended starting point on voltage, but the 1 through 10 markings on the gun itself are absurd because they don't seem relative to anything except each other. That having been said I've tried every combination I can come up with with no success, even a tach weld. First it wadded up the wire inside the spool gun between the wheels and the insulator/tip, etc. So okay, I had the wire feed too tight. Loosened and set it per the internet and next it arc'd internally and fried the drive wheels. Ordered the wheels new and first time I pulled the trigger it melted the aluminum into the plastic insulator tube. Ordered that and immediately fried another one. Internet made it seem that the tip itself may be wrong, although it's what came in it from new. Finally got new tips in after a couple of tries and the minute I pulled the trigger today it welded the alum in the tip where I can't break it loose. NOTHING can possibly be this sensitive to settings that it's impossible to get a starting point with wire speed and voltage without frying stuff internally every time the trigger is pulled. Any advice appreciated or this thing is going swimming.
Spool gun frustration
WHY do people try so hard to make solving a problem they can't solve maximally difficult for someone who might have the answer?
If you don't have or can't find the model number, open the gun up, take pictures, and post the pictures.
I'm 93.75379% positive Bob can't hold the screen up to his helmet and Karnac the answer. I sure can't!
Originally posted by Franz© View PostWHY do people try so hard to make solving a problem they can't solve maximally difficult for someone who might have the answer?
Based on another search for setting up 30A for 1/8 alum I put the voltage at 20.75. (it was on 22) and wire speed at 3.75 on gun. The second I pulled the trigger it welded up another tip. I didn't buy but 5 and that's 2 tonight. I can't believe the average Bubba in the welding shop can use something that's this critical on settings.
Originally posted by Solid Lifters View Post
When I was ordering tips from the local supply house I had to take the tip holder there because I kept telling them it didn't look like the pictures they were showing me. The tip is held in by a collet rather than just a simple screw in.Bob Wright
Let it go swimming and leave the aluminum to the pros, lol. Spool guns are finicky at the best of times. The tips that lock into the collet is the old style and seem to have more issues then the new ones. You can buy the new barrel and it will help some but they are not cheap. I would start with a new liner. There is a little lock nut on the wire spool holder that tightens down on the rubber bushing, its the spool brake. Make sure that is nice and loose and the rubber spins freely. You want just a tiny bit of resistance on the spool, just enough to keep the wire from unravelling. Make sure your using the right size tip for the wire. To small is no good but too big is no good either. When setting the wire speed / voltage start with a higher wire speed then what you think is needed and slow it down until it runs good. This will save you from burning back the tip. Lastly I didn't see what type / size wire you are running. Using 3/64 5356 will probably solve a lot of your problem. Its so much stiffer then the smaller wires, and 4043 is also softer. Also there are 2 groove sizes on the drive roll, make sure your using the right side. The big groove is for 3/64 and the small groove for 0.030 / 0.035. If none of that solves your problems then smash it with the sledge.www.silvercreekwelding.com
Miller Trailblazer 325 efi
Miller extreme 12vs
Thermal arc 186 ac/dc
I bought a used 30a spool gun off ebay and it had the old style barrel with the collet tips. I was having a lot of issues with it. My buddy sent me the new style barrel and that seemed to resolve a lot of the problems. I was still burning up tips like crazy though. It would usually happen when trying to start. At first I liked using 4043 because it welds so much cleaner without any soot. I was using 0.035 wire because I thought the smaller wire was needed for the thin material I was using like 1/8". I think I had tried a roll of 3/64 earlier and was having problems. Like you I wanted to smash it with a sledge hammer. I finally read through the manual a bunch of times and saw that I had to flip the drive roll for 3/64. I did that and put in the roll of 5356 3/64 and voila it was 100% better. I finally managed to weld a whole spool without burning any tips. Now I have a push pull gun and haven't used the spool gun since. Should have bought the push pull first lol.www.silvercreekwelding.com
Miller extreme 12vs
I'll take a swing at some help. I run mine on an older MM250 and from my engine drive. I have an older one so I know how frustrating they can be at times. I run .035 4043 or 3/64" 4043 exclusively in mine. It sounds like a feed issue. I'm sorry I don't have part numbers right now but I'll do my best. Are you running the correct size tip for the wire? There are two different sizes and you need the correct size for the wire you are running. Do you have a knurled drive roll? This is a must for aluminum. Again they have two size grooves. The smaller one is for .035. Is the drive roll aligned? When you install it you must press down slightly to align it with the liner while tightening the set screw on the roller. There is a flat spring that will keep it to high if you don't do this. Wire spool tension, this should be set to the minimum to keep the spool from unrolling on it's own. Mine barely has any tension. The hole in the spool and the rubber tensioner on the gun must be clean and smooth. Sometimes a piece of the sticker on the spool overhangs the hole and gets pushed in there when installing the spool or the glue from the sticker gets in there and gums it up. Does it feed fine into the air? How about if you feed it against a surface with out the ground? Does it keep feeding and just bend the wire?
Where are you located? Maybe close to a member who could check it out in person?Last edited by MMW; 05-19-2019, 05:13 PM.MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Lown 1/8x 36" power roller
Arco roto-phase model M
Vectrax 7x12 band saw
Miller spectrum 875
30a spoolgun w/wc-24
RCCS-14
Not sure how your spool gun is connected to the machine? I just tried to look for an owners manual for the 250x and there are numerous one and they are vague. You have a 10 pin plug that connects to the machine but do you have a pigtail that the main power of the gun connects to? Is the pigtail connected to the + terminal inside the machine?MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
Here are the part numbers. 135430 for .035 tips (the tips will say .035/.052) and 135424 for 3/64" tips (tips will say .047/.061)MM250
Trailblazer 250g
22a feeder
Lincoln ac/dc 225
MM200 black face
Miller spectrum 875
RCCS-14
I have a couple of things that may or may not help. I didn't see them as suggestions so maybe this is something.....The 30-A hooks directly to the regulator on the bottle and not the machine. It has a built in gas valve. You also can partially depress the trigger and pre purge gas around the weld and then fully depress the trigger and feed wire.
If nothing else works, load the spoolgun with normal steel wire the same as the basic machine uses and try the same settings with the spoolgun. That should let you know if things are working properly. Then play with aluminum.
Miller 30-A Spoolgun
Miller WC-115-A
Miller Spectrum 300
Thanks everybody for the suggestions. I'm still struggling with it. I welded a total of about 1/2" today and burned 2 tips in the process. I tried the stiffer .035 wire instead of the softer and was able to weld a millisecond longer before popping the tip again. Someone suggested turning wire speed up, but if I understand correctly this will increase the amperage and I'm right at burning holes now, so I've thought about wire speed up and voltage down, but don't know if that's a good idea. Right now 20.75 V, 3.75 wire speed, 30 on the Argon flow meter.
