Aluminum tank lids
  • Aluminum tank lids
    I was asked today if I could build an aluminum tank for a guy who does asphalt coating. He has a large plastic tank currently about 48" wide, 30 wide and 30 tall. The plastic tank has a threaded cap at the top around 8 or 10 inches diameter. Im looking for ideas for what I could use as a tank lid out of aluminum. He wants it 10 or 12 inch diameter. There are some nice aluminum marine hatches out there but they are too expensive. He doesn't really want anything threaded and in my experience anything that size that is threaded gets stupid expensive. The lid would need to be rain tight but I dont think the product spilling out would be a huge concern. I think its pretty thick stuff that goes in the tank. If theres a reasonably priced fitting that already exist it would be nice but I dont think Im going to find anything. Im thinking to make a square opening and then make a frame out of angle iron to go around the opening. Then a lid out of 1/4" plate with some weld on hinges. A gasket around the frame to keep it water tight. A simple latch mechanism could be used to keep it closed but if I wanted to get fancy I could used a tee handle for tool boxes.
    www.silvercreekwelding.com
    Miller Trailblazer 325 efi
    Miller extreme 12vs
    Thermal arc 186 ac/dc
    Lets start with are you really hard up enough for work to get into the goop tank business?
    Rectangular only unless the customer is providing the hatch.
    Sufdficient size to allow dumping 5 gallon buckets in but not big enough for a bucket to fall in.
    I'd go to 1/4 x 3 flat for the frame recessed minimally 2" into the tank all around. Add a 1/2 x 1 flange on the inside of the frame, to support the door.
    Build the door assembly first, and get it hinged using a rod & pipe mechanism for the hinge. Mount door to frame and add dogging lugs to index dogs holding the cover closed.
    Overbuild dogs and mountings because the help in that industry hammers on everything with a pick ax.
    Weld minimally 3/8 chain across the hinge side to prevent the lid from falling in.
    Might as well add a staple or similar device to help when the lid is pried open.
      What about bolting in a plastic lid?
        Go back to the hammer mentality.
        Make everything badass
        Industrial setting, In the Texas sun, Big mean construction dudes VS plastic china garbage
        If you want a quality marine hatch made from aluminum think about using Bomar in Massachusetts
        You still have any of that stainless from that hood you made?
        Miller 30-A Spoolgun
        Miller WC-115-A
        Miller Spectrum 300
          Actually Im getting really busy and starting a big project next week. I may have some down time waiting for parts and stuff so if I could whip up a tank for these guys then why not. I agree with you about the hammer mentality.
          Miller extreme 12vs
            I don't disagree about what the sun or a construction worker with a hammer can do to a plastic lId. Even the toughest plastic has boundaries. But by the sounds of it, his customer wants a nice tank but doesn't want to spend much and that includes the lid.
            Water tanks on fire trucks are plastic. I think our trucks get worked pretty hard and we have very little trouble with them. The lids are also plastic and exposed to the sun, but we keep maniacs with hammers away from them.
            I do have some stainless left, need some? Make a better lid than plastic, that's for sure.
              How about these?
              Big bucks but no plastic involved.
              https://www.ibctanks.com/stainless-steel
                Looks like a bulk tank for a dairy.
                  Seems the difference between big business and small business is in the use of drawings. Big business supplies a print and says how much to build this. Small business says this is what I want, what can you build me when you figure it out?
                  Then comes the hard choices, buying what's needed or finding what's on hand to make it work?
                  An asphalt coating tank out of Aluminum sounds like someone is sold on the idea of shiny metal bling? What money doesn't buy when an idea or a notion finds a way to spend it. Doesn't carbon steel construction and silver paint seem more suitable for the purpose or is it off the table with a need for Aluminum bling being displayed?
                    Drawings? What are those. I thought I'm supposed to be some kind of mind reader. I dont think its about bling, if you've ever worked around asphalt you know its messy gooey stuff that gets on everything. He mentioned lifting the tank out of the truck when it was empty so Im guessing thats why the aluminum. He said they used to put a crow bar in the tank opening for carrying it. I told him I could put on some lifting lugs or handles.
                    I think I either have to go with a plastic lid or make my own.
                    Miller extreme 12vs
                      Sheesh I'm getting retarted
                      for some stupid reason I had it in my head Ryan was making this instead of Willvis !?!
                      Miller WC-115-A
                      Miller Spectrum 300
                        Probably just didn't have your coffee yet.
                          Don't do anything without coffee lol
                          Miller extreme 12vs
                            I agree. Coffee is the blood of life.
                              So Willvis...you building a tank, a lid, or drinking coffee thinking about it? I had a vision past a square cornered block to something with a more radiused corner, and thought, yea...that's going to look nice out of aluminum.
