Hydrofluoric Acid-WARNING
  • Hydrofluoric Acid-WARNING
    "This extremely corrosive acid is formed when certain types of synthetic rubber, found in some O-rings,oil seals, fuel hoses etc. are exposed to temperatures above 750 degrees F (400 degrees C). The rubber changes into a charred or sticky substance containing the acid. Once formed the acid remains dangerous for years. If it gets onto the skin, it may be necessary to amputate the limb concerned.
    When dealing with a vehicle which has suffered a fire, or with components salvaged from such a vehicle, wear protective gloves and discard them after use."
    The above is a quote from a Chilton's manual. I had never heard of this, Perhaps others are also blissfully unaware.
    ---Meltedmetal
    ---Meltedmetal
    It also is used to etch glass since HF Acid dissolves glass.
      HF Acid is also used and highly regulated in oil refineries. It used to bump up the octane in gasoline since lead was outlawed. It seeks calcium in bones and it will go to your heart. It won't kill you today but a few days. Inhaling fumes in your lungs is real bad also. I had 10 years of use and training updates every year...Bob
        Meltedmetal, thanks for posting. I knew how nasty HF acid was, but did not know you could find it in a burnt car. Thank you.
          Don't you just love having to go work in the alcky unit? NOT!!
          www.silvercreekwelding.com
          Miller Trailblazer 325 efi
          Miller extreme 12vs
          Thermal arc 186 ac/dc
            Yup... I checked the box, was
            blissfully unaware.
              Nope. The smell is terrible...Bob
                I've burned up a few seals and O-rings in the course of what I've done and it never occurred to me that the black sticky mess could be more than a mess. Guess I'll be more careful in the future.
                ---Meltedmetal
                ---Meltedmetal
