Bluestar 2E Rectifier / Regulator Replacement
  • Bluestar 2E Rectifier / Regulator Replacement
    I have an '84 Tecumseh that is not charging the batt. i have 37+vac from the stator and only batt voltage from the regulator. So since I can't get an exact replacement - can I use any small engine 20A rectifier / regulator?
    I pulled the one off a Z-Turn 2 cylinder 20HP Kohler and spliced it in and grounded it and I got 13.6V right off the bat.
    Got on Amazon and is there any way that this one would not work? DB Electrical AKH6003 New Onan Regulator for Rectifier John Deere 318-420 Onan 20 Amps - AC-B+-AC Onan Regulator Rectifier P Series 16hp-20hp 230-22060 HE191-1748 191-2106 191-2208 191-2227 435-175
    Seems like it should - and planning to mount it to the housing similar to like it was for cooling.
    Thanks!
    TB 325EFI
    12RC
    30A/WC24
    Multimatic 200
    Spoolmate 100
    Bluestar 2E DC
    Hypertherm Max30 Air
    Dynasty 210DX
    I dont see a problem with a retro fit it should work just fine
