Replacement Mig Gun MM211
  • Replacement Mig Gun MM211
    I have a new to me inverter MM211 with an HTP flex mig gun. I would like to replace it but am somewhat confused which one to buy. I have 220 in the garage. Max output is 150A and suggested is the MDX100. If you go spool gun they recommend the 150. So is 100A or 150A output?
    I would step up to the M-25 series, which is a 250A gun (60% duty cycle I believe, can't remember). HTP sells it too. I used the 15' gun on mine, but in hindsight, I should have stayed 10ft to reduce feeding issues.
    HTP Pro Pulse 300 MIG
    HTP ProPulse 200 MIG x2
    HTP Microcut 875SC
      Thanks for the response. I heard about the 15' having issues and hoped it was an isolated issue here or there. I will go with the 250a gun and keep it short I guess.
        Anything wrong with the HTP gun?
        No need to buy a 250 amp gun for a MM211.
        MM211 is rated 150amps at 40% duty cycle drops to 20% at 200amps
        The MDX 100 is $149.00 It is rated 100amps 100% using CO2 60% using mixed gas.
        MDX 250 is $274.00
        Ed Conley
        MM252
        MM211
        Passport Plus w/Spool Gun
        TA185
        Miller 125c Plasma 120v
        O/A set
        SO 2020 Bender
        You can call me Bacchus
          True, it's not needed but the 10' HTP M-25 gun is about $160, and uses all miller parts except for the liner.
          HTP Microcut 875SC
            That's a good price for the HTP gun.
            Ed Conley
            MM252
            MM211
            TA185
            O/A set
            SO 2020 Bender
