Blown F5 fuse on Trailblazer 325
  • Blown F5 fuse on Trailblazer 325
    I’m currently troubleshooting a Trailblazer 325 with the Kolher Gas engine S/N MH040162R. Engine will only run at idle. During start up the F5 fuse will blow. Owner was using welder as a generator during a power outage for a couple days when it suddenly dropped to idle and now blows the fuse. Is curcuit board PB1 bad or is another fault causing the problem. Any advice would be greatly appreciated.
    Check the rotor for 15 OHMs across the slip rings. If that is good yes PC1 is likely bad. This machine is still under warranty.
