HYPERTHERM Duramax torch on a Everlast 100a plasma
  • HYPERTHERM Duramax torch on a Everlast 100a plasma
    Up date on the conversion. It works flawlessly. It's got enough arc time to prove itself a successful conversion. I have had zero misfires, Current went down, inches per minute went up, consumable life is great. Still produces square dross free cuts with worn consumables. Its definitely a great upgrade. Probably the best upgrade you could do to a everlast plasma cutter. I had to make a modification to the torch wiring so the torch needs to be split. Clip the orange wire out of the trigger circuit and blank it off on the machine end. This leaves the head/consumable switch in series with the trigger circuit so if the consumables are loose or installed incorrectly it still will not fire as the machine wont receive a completed "fire circuit". My guess is the orange wire signals the air supply in the HT units. I am not sure but it's not needed with the everlast. Click image for larger version  Name:	20190211_205614.jpg Views:	3 Size:	72.1 KB ID:	595106Click image for larger version  Name:	20190211_205622.jpg Views:	3 Size:	70.3 KB ID:	595107Click image for larger version  Name:	20190212_214825.jpg Views:	3 Size:	36.5 KB ID:	595108Click image for larger version  Name:	Screenshot_20190212-215202_Gallery.jpg Views:	3 Size:	28.5 KB ID:	595109
    Last edited by sledsports; 02-14-2019, 01:04 AM. Reason: Felt i left to much out like a dummy.
    Dynasty 400 Wireless
    Coolmate 3.5
    Aerowave loaded with Sequencer and pulse
    ​Watermate 1A
    ​Coolmate 3
    XMT350 CC/CV
    D74DX Feeder double the fun
    Optima Pulse Pendant
    WC24
    30A spoolgun
    Neverlast 100 amp plasma with Hyper Duramax torch
    Avortec 280 mig
    GO CNC Poweredge CC/CV pulse and double pulse
    Harris Old school 2 stage Oxy/Ace
    Victor flow meters
    Flametech Duel flowmeters
    Just a hilljack in the woods with fancy welding equipment
    and a pet Raccoon.
    While I didn't go back and see how I may have responded to the idea originally, I'm sure It was probably something of a why response? That's typical of me?
    If memory serves, the response was a gun cable length improvement, gun comfort, gun consumable favor in durability, longevity and pricing. All good reasons in my book for answers why?
    You had an idea and went with it, did it and noticed improvement, it classifies as hot rodding.
    I like it.
      I like it.
      I kinda hi jacked my own original thread up so I started with on the right foot this time. All of things you stated are exactly why I did it. I got to thinking... I see this often and I have seen it right here in the Miller forums . Only one name in Plasma air cutters and thats Hypertherm. It's not magic but they seem to be the step ahead of everyone else as far as performance... my wheels got to turning. How? It's a add voltage to the nozzle for a pilot arc and Current to the electrode to make up with the ground... add air and you have a plasma stream. Thats how all blowback torches work.The rocket science is in the torch head. It's how that air is added. It's the swirl ring design, it's the nozzle design, it's the electrode design and the shielding. It's not the power source. The power source doesnt care what's on the other end.They all work the same way. The torch is dumb. It doesn't care where it gets it's current or air. It does what it wants to with it. Was told many times... that wont work. Incomparable with each other.... bla bla bla bla... it works. It's a superior torch.
      Coolmate 3.5
      ​Watermate 1A
      ​Coolmate 3
      XMT350 CC/CV
      WC24
      30A spoolgun
      Avortec 280 mig
      Victor flow meters
      and a pet Raccoon.
        And no Noel... this thing will never replace my Harris hand torch. The nitty gritty burning will still be done with it lol. This what I'm gonna use on this hobby table
        Coolmate 3.5
        ​Watermate 1A
        ​Coolmate 3
        XMT350 CC/CV
        WC24
        30A spoolgun
        Avortec 280 mig
        Victor flow meters
        and a pet Raccoon.
          Can you tell me where you got that connector with the pins and all? I'm currently looking for one of those.
          HTP Pro Pulse 300 MIG
          HTP Pro Pulse 200 MIG x2
          HTP Pro Pulse 220 MTS
          HTP Microcut 875SC
            Plasmadyn on Ebay has all the necessary parts. Make sure you get a 8mm airline barb with the climp clamp
            Coolmate 3.5
            ​Watermate 1A
            ​Coolmate 3
            XMT350 CC/CV
            WC24
            30A spoolgun
            Avortec 280 mig
            Victor flow meters
            and a pet Raccoon.
              Coolmate 3.5
              ​Watermate 1A
              ​Coolmate 3
              XMT350 CC/CV
              WC24
              30A spoolgun
              Avortec 280 mig
              Victor flow meters
              and a pet Raccoon.
                Nice thank you. I was searching for "power connector", hence why I didn't get too good of a result, lol.
                HTP Microcut 875SC
                  Are you repairing yours or retrofitting a different torch to your HTP? You can probably reuse your hose barb. Might want to send a message if you order from them to send you the correct size climp clamp. Theres 2 different sizes. 6mm and 8mm.
                  Coolmate 3.5
                  ​Watermate 1A
                  ​Coolmate 3
                  XMT350 CC/CV
                  WC24
                  30A spoolgun
                  Avortec 280 mig
                  Victor flow meters
                  and a pet Raccoon.
                    Just trying a little something off-the-wall.
                    HTP Microcut 875SC
                      Sounds like something I did...that everyone and their brother said wouldn't work. Go for it and send me pictures!!!!
                      Coolmate 3.5
                      ​Watermate 1A
                      ​Coolmate 3
                      XMT350 CC/CV
                      WC24
                      30A spoolgun
                      Avortec 280 mig
                      Victor flow meters
                      and a pet Raccoon.
                        Yup, I'll post it up when I succeed. Just look at the 4th line of my sig.
                        HTP Microcut 875SC
                          I like the way you think.
                          Coolmate 3.5
                          ​Watermate 1A
                          ​Coolmate 3
                          XMT350 CC/CV
                          WC24
                          30A spoolgun
                          Avortec 280 mig
                          Victor flow meters
                          and a pet Raccoon.
                            Was this still alot cheaper then just buying a hypertherm plasma cutter? How do you like that plasma cutter? Ive been hearing pretty good stuff about these everlast welders. I'm gonna pick up one of their tig coolers soon. Eventually maybe I'll get their biggest tig welder and a plasma.
                            www.silvercreekwelding.com
                            Miller Trailblazer 325 efi
                            Miller extreme 12vs
                            Thermal arc 186 ac/dc
                              Yes. I'm into it about 2k. Gotta good deal on a new torch off Ebay. It cuts very nice. A 100 amp plasma cutter from Hypertherm is what? 4500-5k? I am sure the unit itself isnt as robust and well built as a HT but they all do the same thing... provide current.
                              Coolmate 3.5
                              ​Watermate 1A
                              ​Coolmate 3
                              XMT350 CC/CV
                              WC24
                              30A spoolgun
                              Avortec 280 mig
                              Victor flow meters
                              and a pet Raccoon.
