wishing this thread had not got hijacked because theres just not that much info out there on this subject. I'm trying to learn to tig small tubing myself. it was going along with great advise until the hijack. oh well...
Welding smaller pipe.
Originally posted by bevis View Postwishing this thread had not got hijacked because theres just not that much info out there on this subject. I'm trying to learn to tig small tubing myself. it was going along with great advise until the hijack. oh well...Richard
West coast of Florida
- 1 like
I've attached 5 for your pleasure. The goal of this experiment was to prove a few points. Three points actually.
The first was, if they were all at the same arc length, all at the same amperage, which would create a puddle at the lowest amperage setting. The goal was simple, only enough heat to melt and fuse, but not melt threw to the back side.
The second was, at that setting, which would create the deepest penetration, narrowest bead width and use the least filler. The idea was it's easy to weld big, hot, and excessive, most materials are quite forgiving. Understanding what affects the weld profile, small an penetrating is achievable.
The third...well, that had to do with arc plasma theory and would probably just mess up your mind for a good nights sleep, but assuming your a thinker, there's arc physics involved.
However, on a simple level, it's how the shielding gas, in this case Argon, creates it's path and shape.
Now...remember tungsten comes in different sizes. Different types as well. Kind of like pencils. Studies have shown those arc characteristics enhance or detract depending on the application, currents, power source type.
The spin off in this small effort was also a few other points. The effects on arc length and voltage to puddle formation and viscosity. The effect of a high frequency current and the path it took for a setting of intensity. As well, high and low CFH and how it had an effect.
As far as the grinding into shape marks, lol...I don't have a diamond disc and as coarse as they appear, they were mostly ground longitudinal. Lol...they were spun quickly into shape and if it was more a concern for the sake of science it would have been held to a tighter more refined result. I might have used a flap wheel.
One more thing...when you look over the pictures, reading this commentary, that of others...what are you learning? Tig welding small tube? No, your not learning that, your getting advice on what to learn. What you learn, you must apply.
I'm with the other's...Oh well? Add to the conversation or start a different one. You to could have the honor of bars and title. Be involved.
From where I'm sitting and typing, you're being a Butthead Bevis, pardon the pun. Aheh,aheh,aheh.
Tell you what, start that new thread and call it "Here's my small pipe welds, what can I do to improve them?".
Put it out there and see what bites the line? I'd be all over it.
Give us something else to talk about and we will.
5 Photos
- 1 like
Originally posted by bevis View Postwishing this thread had not got hijacked because theres just not that much info out there on this subject. I'm trying to learn to tig small tubing myself. it was going along with great advise until the hijack. oh well...Dynasty 400 Wireless
Coolmate 3.5
Synchrowave 350LX loaded with Sequencer on the cooler
XMT350 CC/CV
S74DX Feeder
Optima Pulse Pendant
WC24
30A spoolgun
Neverlast 100 amp plasma with Hyper Duramax torch
Avortec 280 mig
Harris Old school 2 stage Oxy/Ace
Victor flow meters
Flametech Duel flowmeter
Just a hilljack in the woods with fancy welding equipment
and a pet Raccoon.
- 1 like
