Difference between push pull guns
  • Difference between push pull guns
    Does anyone know if a miller push pull gun can be used on a lincoln or vise versa. Is the difference just in the amphenol style connector, and can that be changed to suite the powersource / feeder?
    www.silvercreekwelding.com
    Miller Trailblazer 325 efi
    Miller extreme 12vs
    Thermal arc 186 ac/dc
    I can tell you for sure that the power pins are different between a Lincoln and Miller. Most guns can be adapted from one to the other, although sometimes it can be kind of a bugger to find the right parts if you’re not patient enough to look it up yourself or don’t have a very helpful lws. God forbid you ask somebody from Airgas to get you a miler power pin to put on a mag pro gun (personal experience)
    As for the multi pin I doubt they’re the same, but I have to imagine you could change it over if there isn’t an adapter pigtail already available.
    Blue: 325 Trailblazer, 225g plus Bobcat, arc reach 12vs, 8vs, XMT350, Syncrowave 200, Cp200 & 10a feeder, Roughneck 2E
    Red: Power Mig 256, Power Mig 350mp, Python push-pull
    Other nonsense: F550 with 5k crane, welder compressor, torches, and every thing else...
    Koike ik-12 beetle track cart, TD cutmaster 82 (hate it) all torches are propane, Bridgeport mill, lathe, press, small brake, Milwaukee mag drill, Jd squared 32 bender, speeder 9x16 horizontal saw, things I can’t remember...
