Spool gun vs suitcase
  • Spool gun vs suitcase
    I've read some previous posts, I have a millermatic 180 I can run off my bobcat if need be, I'd rather leave that in the shop.
    What are the pros and con's for a spool gun/ suitcase mig?
    Bigger spool in a suitcase, normal welding mig gun with it too.
    Spool gun makes aluminum easy and it's probably cheaper.
    That's right off the cuff this morning...no research required there.
      If you are going to do mostly steel then the suitcase is the way to go. Bigger spools of wire equals cheaper cost to purchase. The ability to run larger diameter wire is a major plus when working anywhere.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Lown 1/8x 36" power roller
      Arco roto-phase model M
      Vectrax 7x12 band saw
      Miller spectrum 875
      30a spoolgun w/wc-24
      RCCS-14
        Be more specific.
        Do you want a spoolgun and a suitcase or either/or?
        To run a spoolgun off of a Bobcat (at least the 30-A) you will need a WC-115A with the contactor installed. Not cheap but could make you a lot of money welding aluminum.
        The suitcase is also a professional piece of welding equipment and could stand up to heavy abuse and usage on steel.
        I say get a new 210 Dynasty and run it off your Bobcat and become a mobile tig welding guru.
        Miller 30-A Spoolgun
        Miller WC-115-A
        Miller Spectrum 300
          I like the suitecase for wire welding off the bobcat. It’s the way to go. I don’t do much if any aluminum.
          Lincoln Idealarc 250
          Miller Bobcat 250
          Thermal Arc Hefty 2 feeder
          Thermal Dynamics Cutmaster 52
          Torchmate CNC table
            I honestly wouldn't get involved with aluminum right now, it sounds like the suitcase is the way I'll go. I was looking for other options instead of lugging my millermatic 180 around.
              If you go the suitcase route (I would recommend it if you think you’ll use if on any regular basis) just make sure you get your hands on a voltage sensing unit and not one that has a remote cable. Your bobcat doesn’t have a 14 pin and if I’m correct will not work with a remote feeder
              Blue: 325 Trailblazer, 225g plus Bobcat, arc reach 12vs, 8vs, XMT350, Syncrowave 200, Cp200 & 10a feeder, Roughneck 2E
              Red: Power Mig 256, Power Mig 350mp, Python push-pull
              Other nonsense: F550 with 5k crane, welder compressor, torches, and every thing else...
              Koike ik-12 beetle track cart, TD cutmaster 82 (hate it) all torches are propane, Bridgeport mill, lathe, press, small brake, Milwaukee mag drill, Jd squared 32 bender, speeder 9x16 horizontal saw, things I can’t remember...
                I've seen a couple LN-25's locally for sale. Thoughts on those?
                  The LN-25 is an excellent suitecase feeder. It is a voltage sensing unit just like millers 12vs model.
                  Either the LN-25 or the suitecase extreme 12vs would be great machines.
                  Miller Bobcat 250
                  Torchmate CNC table
