Saying hi
  • Saying hi
    I'm a newbie here and at welding for the most part.
    I've been mig welding our own farm equipment for about 4 years, I'm in the market for a welder generator. Local shop has a 225 bobcat with 300 hours for $2k. I'm on a budget being a dairy farmer, I've also purchased a service truck and plan on doing some side wrenching/ welding. Any advice is greatly appreciated. Thanks
    That machine sounds like it could be a good deal for you as long as it has been kept up decent.
    Miller 30-A Spoolgun
    Miller WC-115-A
    Miller Spectrum 300
      Back on the farm, I didn't even know there was such an animal as a mig welder. As far as I knew there was only 6011, or whatever rod was laying around the machine shed.
        Welcome, Farmerstinky. Planning on stick welding with the Bobcat, or are you going to hook up a wire feeder? Or use it to power your existing MIG welder?
          All of the above, (won't have a wire feed right away), my mig is a millermatic 180.. eventually id like to get a plasma cutter also. A hypertherm 45.
            I've only stick welded a few times
              Welcome to the forum! I burned rods for many of years before even knowing about much less burning wire. The bobcat should serve you well if kept up with maintenace and in good condition.
              A FEW OF MY TOYS !!!
              MX Linux
              LinuxMint
              Miller Roughneck 2E
              Lincoln Weldpak 100
              Gianttech Arc 200
                Get that Powermax 45 as soon as you can. Someone here described it as "puts a smile on my face every time I use it." That's my thought exactly. I cannot believe how well that thing works. From 22ga aluminum to 5/16 steel plate and everything in between, it is just amazing. And cutting expanded metal with the special mode for that function is fantastic. You will love it, and wonder how you did without it.
                  Got it home
                    Looks good. Let us know how it welds.
                      Nice score. First thing I would do is open that sucker up and blow out all the crud/dust/dirt/grime that inevitably builds up.
                      HTP Pro Pulse 300 MIG
                      HTP ProPulse 200 MIG
                      HTP Microcut 875SC
                        And make sure it has the right oil in it.
                          Which is? no manual with it
                            Use the serial number HERE to get the manual
                            Richard
                              There was a long thread some time back about the proper oils to use in those air cooled engines. The gist of it was using regular old car engine oil does not have the proper additives, like zinc, to protect the internal components of that welder's engine. There was a list of classifications that was laid out to help determine the correct oils that can be used. That thread had some really good info in it too, so maybe one of the computer literate fellers can find that link.
                              I use valvoline VR1 30wt racing oil in all my small engines. It's supposed to have all the right additives since it's not made for on road driven cars and it's readily available at my local parts store. The only exception is my Onan genset in my RV, I use the Onan oil for that.
