FS: Millermatic 211 Inverter with Spoolmate 150 & lots of extras
  • FS: Millermatic 211 Inverter with Spoolmate 150 & lots of extras
    Well my Miller family, the time has come. Gonna part ways with my Millermatic 211 Inverter. Now have an HTP Pro Pulse 300, so gonna let this one go to someone who will hopefully make good use for it.
    It is a bundled package.
    It includes:
    • Qty:1, Millermatic 211 Inverter Welder w/ main board replaced by Welding Machine & Torch Repair in San Antonio, Tx (was done June 2018). Drive motor assembly replaced about 8mo ago or so. All knobs and AutoSet features work as intended. Gas solenoid works as intended as well of course.
    • Qty: 1, Miller 211 machine cover
    • Qty: 1, replacement ground clamp (already installed, larger than stock)
    • Qty:1, Miller M100 MIG gun w/stock liner
    • Qty: 1, stock 8" spool adapter with plastic nut
    • Qty: 1, Miller M100 0.045" liner
    • Qty: 1, Miller stock 0.023"/0.030"/0.035" drive roll
    • Qty: 1, Miller 0.035"/0.045" flux core drive roll
    • Qty:1, HTP M25 250A, 15-foot MIG gun with stock 0.030"/0.035" Liner
    • Qty:1, HTP M35 0.030"/0.035" replacement liner
    • Qty: 1, HTP M25 0.023" liner
    • Qty:21, Miller 0.030" tips
    • Qty:1, Miller 0.023" tip
    • Qty: 5, Miller 0.035" tips
    • Qty 20, HTP 0.045" tips
    • Qty: 3, M100 copper nozzles
    • Qty:2, HTP 3/8" M25 nozzles
    • Qty:1, HTP 1/2" M25 nozzle
    • Qty: 2, Miller flux core nozzle shroud
    • Qty: 1, Miller 6-50P 240V Plug
    • Qty: 1, Miller 120V, 15A plug
    • Qty: 1, Miller 120V, 20A plug
    • Qty: 1, Miller Spoolmate 150 (used only once to make sure it works)
    • Qty: 2, Miller Spoolmate 150 stock nozzles
    • Qty: 44, generic Spoolmate 150 0.035" tips
    • Qty: 5, generic Spoolmate 150 0.030" tips
    • Qty: 1, generic ER4043 aluminum spool, 2lbs (installed in Spoolmate)
    • Qty: 3, HTP M25 diffuser/tip holders
    • Qty:3, HTP M25 diffuser adapter
    • Qty: 3, HTP M25 plastic heat insulators
    Only part missing is the original tension spring, so I made my own out of 1/16" SS tig rod.
    $799 firm, plus shipping to your door. Box size would be approx. 28" L, 16" W, 18" H. Shipping weight approx 55lbs. I prefer Check/MO/Cashier's check. Paypal accepted if you cover fees. My ZIP is 78045.
    HTP Pro Pulse 300 MIG
    HTP ProPulse 200 MIG
    HTP Microcut 875SC
    Oscar, what year did you buy this, and why was the main board replaced?
    Thanks
    Richard
      I bought it in Oct 15. I believe I may have ran it past it's duty cycle, and it shut off on me and never turned back on. This was back in June of this year. Dropped it off at the Miller repair center in San Antonio, and they said they replaced the main board under warranty. Works just as it did before. Tension at the drive roll must be set higher than the mid-point scale on the tension knob because the drive motor/roll assembly has a slight wobble, so it loses grip on the downward half of the rotation, unless it is compensated by adding tension with the knob. Works just fine when this is setup correctly. I was welding those 5"x5"x4.8mm red square tubes in the background with it just a couple weeks ago. Gonna finish off that rack with my new HTP Inverarc 200 TLP stick welder though.
      Make me a good offer with a payment by check/MO/cashier's check and I just might bite.
      HTP Microcut 875SC
        Sold on Ebay.
        HTP Microcut 875SC
          Originally posted by OscarJr View Post
          Sold on Ebay.
          I knew that wouldn't last long
          Richard
            I was kinda surprised it went so fast. So I guess that's it, I suppose I'm now banned from these Miller forums as I now do not own a Miller machine, lol.
            HTP Microcut 875SC
              Hopefully you get a pass, but just this one time!
              Richard
