I need a good general purpose saw for cutting metal projects. My immediate needs are to cut 1" round and square tubing with .125" wall thickness I'll be using to fabricate a mounting bracket for a set of Tilton overhanging master cylinder/pedal assemblies in my car. I also need to cut some 1"x2" square tubing to make up some seat adapters. I've done a search on this forum for "cutting tubing" and read a lot of good advise, and the choice appears to be between a chop saw and a 4"x6" bandsaw. Since my shop is a 1/2-car bump-out in my garage I'm leaning towards the bandsaw as it sounds like the bandsaws produce a lot less dust, which is important as my car-in-progress sits next to my shop area, with various expensive engine-innards covered but still susceptible to contamination during the fabrication.
Any suggestions either way?
