Miller big blue 500pt voltage drop
  • Miller big blue 500pt voltage drop
    Any advice would be appreciated, my 240 volt output is only reading 227 volts. What would cause this? Ive already changed brushes and capacitor. Any suggestions?
    What's the HZ reading? Could be as simple as low RPM's.
      I will check the frequency and the rpms , any Idea what the high idle rpm and hz should be ? I will check in the manual.
        60-65 HZ should get you 120-130 on the 110v plugs.
