Miller 243
  • Miller 243
    Need help I have a Miller 243 Compactblu. It says it 3 and single phase it that correct. It works on 3 phase. And says on the side it has 240v aswel. Can anyone help please
    Lots of modern machines are made with technology that allows them to be run from single or three-phase, and at several voltage ranges.
    Where are you located? Is this a US machine?
      I’m from Ireland. It’s a old machine. I have changed over the inside like it’s says but left with a black wire at the plug which is black. What do I do with it
          I'm not wholly familiar with your power system there, but just because the plate says 240v doesn't mean it's single phase. Are you sure it's a single or three phase machine?
            William, looking at the jumper diagram, yes, your machine can be wired for 240V, but I believe it to be 240V, 3 phase only. Does the machine have a data plate on it?
              With those pictures, I'm with the consensus. That's a 3-phase-only machine.
                  Bottom left corner.
                    Yep--3-phase only.
