Millermatic 130 wire feed trouble
  • Millermatic 130 wire feed trouble
    Hi, I've an old millermatic 130 with a trouble on wire feeder. I've set a voltmeter on positive and negative nuts of TE1. Voltage are between 20v and 28v when feeder running good but when I release the trigger it drop to zero 3-4 second. To be able to weld again, I need to push triggee many time and after that the voltage on n├ęgative and positive nuts back to 20v - 28v.
    Did you have any idea of wich part must replace?
    Sounds like the contactor points are buttered and not making good contact every time. Take the cover off the contactor and look at the bars. I bet you see they are blackened and pitted.
