250x burn back problem
  • 250x burn back problem
    Hi, I’m new to this forum. I’ve searched and found a lot of useful information about my problem but I need some additional details before make this modification. I’ve got a 250x and it’s burning back and fusing to the tip. From what I’ve read there is a diode that I need to clip to disable the hot start. The welder runs great on 1/8” on up but 22 gauge in having the issue. The board number is a 196456. I messaged Kevin hoping I hear back from him. Any information will be greatly appreciated.
    What gas and wire you running?...Bob
      75/25. Welds great info can keep it from burning back
        On that particular unit clipping D-1 off the main control board will disable the hot start circuit. This may address the burn back issues you are having. You will also want to check the feed-ability of the wire, a feeding issue could also cause burn back issues.
        Kevin
        Kevin Schuh
        Service Technician
        Miller Electric Mfg. Co.
