2008 Lincoln Vantage 300 brushes
  • 2008 Lincoln Vantage 300 brushes
    I have a 2008 Lincoln Vantage 300 with 2511 hours. It is working fine. I just wondered about how many hours are recommended before new brushes are needed?
    Vantage 300 Service Manual states to replace brushes when 1/4" from their maximum travel.
    Syncrowave 180 SD
    *HF-251D-1
    *WC-1S & Spoolmatic 1
    PakMaster 100XL
    Marquette "Star Jet" 21-110
      It’s difficult to see the brushes as they are. They are behind what looks like a large bracket that is likely holding them in place. Can I just remove this to inspect them, assuming they are attached to it?
        Yes, you can remove the brush holder bracket if needed to confirm total available brush travel.
        Forward an email address via Private Message and I'll send you the Vantage 300 Service Manual in .pdf format.
        Syncrowave 180 SD
        *HF-251D-1
        PakMaster 100XL
          On a tuned V300/400 , 5000 hrs min
