Syncrowave 351 tig problem
  • Syncrowave 351 tig problem
    Has anyone had an issue with their syncrowave 351 operating fine in stick mode but when you switch to tig, the meter just shows "000" on the amp display and won't allow a max amperage to be set? The gas also comes on when the foot pedal is pushed but when released, the gas stays on until you turn off power to the unit. The remote foot pedal has been switched out with a known good unit but doesn't make a difference. Would this be a control board issue?
    It sure sounds like a PC1 control board issue. Unfortunately that board has been obsolete for awhile.
      Not only obsolete but referred to a replacement which is also obsolete. I am looking at company that says they can repair it. Thank you for the input.
