Miller Suitcase Extreme 12vs
  • Miller Suitcase Extreme 12vs
    We have currently been using a Miller Suitcase Extreme 12vs paired with a Miller XMT 350vs. Up until now it has worked great. Then all of a sudden the gas purge shuts off after about seven seconds when welding. The solenoid seems to be working. When the purge button is pushed the gas flows until you release the button. Any thoughts or help would be appreciated.
    Ask yourself these questions.
    1) is the switch functioning?
    2) is there an electronic module or relay working from the switch connection signal?
    3) have you given any thought to how you test to be sure?
    https://www.millerwelds.com/files/ow...52203H_MIL.pdf
    Now, because you didn't get the brightest bulb in the box replying, I'm going to suggest a simple check. Put a balloon, plastic bag over the end of the nozzle and hit purge, does the pressure build continuously or does it drop off?
    If it builds, grab the tape to hold it down and keep welding? You'll go through gas like crazy but it should work?
    Now as far as finding the actual problem, or giving you a simple this is it on how, I don't have it to give. But I'm sure it's fixable.
      Try changing the mig gun, it could be in the trigger.
      Millermatic 252 w/30A
      Big Blue Air Pak
      Ellis 3000 Band Saw
      Trailblazer 302 Air Pak w/ Wireless Remote
      8-RC
      XMT 350 MPa w/S-74 MPa Plus
      Millermatic 211
      Passport Plus
      Spectrum 625 X-TREME
      Lincoln SA-200 Blue Tint Red Face '63
      2-Lincoln SA-200 Red Face '68
      SA-200 Black Face '59
      SA-200 Green Lite '84
      SA-200 Green Lite '80
      SA-200 Red Face '69
      SA-200 Red Face '66
      SA-200 Green Lite '81
      '70 Black Face Round Barrel
