Old Model 250 ac/dc HF Problems
Cool; to quote the guy on the A team, "I LOVE it when a plan comes together" :=)) ...Steve
The diode came in yesterday. I swapped it out, fired it up, and I'm back up & running! Thanks again everyone for walking me through it
"I'd just change the one--others opinions may differ. Can you find a part number on it?"
I agree - IMO, the three that survived are proven TOUGHER :=) -
on part #, watch out for an "R" in it - a lot of bridge rectifiers on old stuff only used TWO heat sinks (save money) - so HALF of the diodes had the CATHODE on the end that BOLTS on, the OTHER HALF had the ANODE on the bolt.
Other diodes may just have different part # for straight or reverse polarity, so...
Lacking an "R" in the part #, if your machine has 2 heat sinks and 4 diodes, make SURE you check the pn# of the one that's BAD, not the one that's easier to read... Steve
Internet craziness today, ignore me.
---MeltedmetalLast edited by Meltedmetal; 08-09-2018, 07:51 AM.
I'm in the camp of if it ain't broke, or obviously about to break, don't fix it.
I have to say--another old guy thing, I guess--I never use the diode test/beeper unless I'm simply testing for wire continuity and I need to hear the beep from many feet away. Don't think I've ever used it even once to check a diode.
You guys were right... the beeper selection has a ceiling below the resistance I was getting (300 I believe). I selected a higher range, and presto. 3 of them check out & one is trashed. Should I just replace the one, or all 4 & the resistors while I’m at it?
I agree with Steve--I'm not sure you have four failed diodes. While I have more digital meters than any reasonable person needs (I'm like that with welders, too.....), when I'm testing diodes I like to grab one of my trusty old Simpson 260s. Love to see that needle swing. Not that you can't do it with a digital meter--I can and do, but being an old guy I still like some of the old ways, and this is one of them.
How did you test the ones that gave no indications? Here's what I would do: Don't use the diode test/beeper range on the meter--use ohms. Connect the leads solidly with alligator clips, and get a resistance reading in one direction. If your meter has autoranging, turn it off as Steve suggests. You may have to switch scales until you get a reading. Then do the same thing with the leads reversed. I'm guessing you only have one bad diode. I think you are going to find the other three have low resistance one way and high the other.
Digital meters can be tricky, I'm wondering if your other three diodes are actually OK - I would check those 3 again, this time setting your meter to NON autorange, and check each one on several different MANUAL ranges - it's possible you might get a reading of some kind, also if your meter has a "diode" setting THAT's the one I'd use... Steve
Since it works perfectly in AC, like you said, I'd think the transformer is probably unscathed, by and large at least.
I’m hopeful for the transformer as well. There was no smell, smoke, pop, etc.
Isn’t it extremely unlikely that all 4 diodes failed in a matter of hours without something else causing them to?
