Since it works perfectly in AC, like you said, I'd think the transformer is probably unscathed, by and large at least.
Old Model 250 ac/dc HF Problems
Digital meters can be tricky, I'm wondering if your other three diodes are actually OK - I would check those 3 again, this time setting your meter to NON autorange, and check each one on several different MANUAL ranges - it's possible you might get a reading of some kind, also if your meter has a "diode" setting THAT's the one I'd use... Steve
I agree with Steve--I'm not sure you have four failed diodes. While I have more digital meters than any reasonable person needs (I'm like that with welders, too.....), when I'm testing diodes I like to grab one of my trusty old Simpson 260s. Love to see that needle swing. Not that you can't do it with a digital meter--I can and do, but being an old guy I still like some of the old ways, and this is one of them.
How did you test the ones that gave no indications? Here's what I would do: Don't use the diode test/beeper range on the meter--use ohms. Connect the leads solidly with alligator clips, and get a resistance reading in one direction. If your meter has autoranging, turn it off as Steve suggests. You may have to switch scales until you get a reading. Then do the same thing with the leads reversed. I'm guessing you only have one bad diode. I think you are going to find the other three have low resistance one way and high the other.
You guys were right... the beeper selection has a ceiling below the resistance I was getting (300 I believe). I selected a higher range, and presto. 3 of them check out & one is trashed. Should I just replace the one, or all 4 & the resistors while I’m at it?
I have to say--another old guy thing, I guess--I never use the diode test/beeper unless I'm simply testing for wire continuity and I need to hear the beep from many feet away. Don't think I've ever used it even once to check a diode.
I'd just change the one--others opinions may differ. Can you find a part number on it?
Internet craziness today, ignore me.
---MeltedmetalLast edited by Meltedmetal; 08-09-2018, 06:51 AM.---Meltedmetal
"I'd just change the one--others opinions may differ. Can you find a part number on it?"
I agree - IMO, the three that survived are proven TOUGHER :=) -
on part #, watch out for an "R" in it - a lot of bridge rectifiers on old stuff only used TWO heat sinks (save money) - so HALF of the diodes had the CATHODE on the end that BOLTS on, the OTHER HALF had the ANODE on the bolt.
Other diodes may just have different part # for straight or reverse polarity, so...
Lacking an "R" in the part #, if your machine has 2 heat sinks and 4 diodes, make SURE you check the pn# of the one that's BAD, not the one that's easier to read... Steve
