Water Cooled TIG Torch for a Dynasty 280DX
  • Water Cooled TIG Torch for a Dynasty 280DX
    Hello folks,
    I am in the market for a water cooled TIG torch because I am tired of constantly running my gas/air cooled CK FlexLock over it's capacity of 150 amps. I am looking at the CK200 (250amps @ 100% duty cycle on both AC and DC) and the Wledcraft W-310 (formerly CS310). There is a lot of positive reviews online about the CK200 but almost non about the W-310. Has anyone got some experience with the W-310 they would like to share? I understand that the advantages of the CK200 are that it has a higher rated output on AC, a much larger water jacket and it is cheaper than the W-310.
    I am interested in the W-310 because of the unique triangular handle that has self-indexing flat top for easier torch orientation, but I am a bit bothered by the fact that it's only rated for 235 amps on the AC side, I could perhaps ignore that since I don't do AC welding anyway. All inputs are welcomed.
    Look into the WeldTec SpeedWay tig setup. Rated at 320A AC and DC.
    HTP Pro Pulse 300 MIG
    HTP ProPulse 200 MIG x2
    HTP Microcut 875SC
      The CK 230 is a 300 amp 100% AC/DC duty cycle torch, and uses the same consumables (series 2) as the CK200
      This would allow you to use the 280dx at full amperage
      Richard
        I didn't even know that torch exists. Did a bit of searching around and it seems like a great torch, not a whole lot of reviews but the few I found were very positive, and the price is OK. Thanks Oscar
        You should add the new welder to your signature here
          Thanks Richard, I didn't consider it because I was aiming for the smallest torch I could find and the CK230 looked tempting but has a larger diameter handle. That's why I was asking about the CS-310. I have no plans on going over 250 amps.
            I don't think you can add signatures here on the Miller forums.
            HTP Microcut 875SC
              The 280 DX ships from the factory when you buy the kit with a Weldcraft W-280........formerly a WP-280.....if you have consumables from an existing older WP series torch..........you can still use them in the W-280...........I like the new 280 cause it's built on the older WP small frame.....more comfortable in my hands.........and with gas lenses I can get anywhere.....
                I don't have any experience with the Weldcraft- but I do have the CK 200 with the Superflex cables on my Dynasty. I previously had the gas cooled FlexLock and loved it. I just got tired of having to let it cool down. I switched to the water cooled version with a Coolmate 1.3. Now I can run 200 amps on A/C and the torch body doesn't even get warm. The only downside is that the CK torch handle is so slim that my finger control won't tighten on the handle. But, I use a foot pedal most of the time-so not a big issue.
