98 camaro aluminum driveshaft alloy?
  • 98 camaro aluminum driveshaft alloy?
    Anyone know what alloy it is? Customer dropped off one today that the tube rubbed on the driveshaft loop and put a groove in it. I need to weld it up and sand smooth. Can't find the answer doing a quick search on the web. I know it may be out of balance when done and possibly weaker in the haz which I'll relay to the customer. My guess is 6061?
    MM250
    Trailblazer 250g
    22a feeder
    Lincoln ac/dc 225
    MM200 black face
    Lown 1/8x 36" power roller
    Arco roto-phase model M
    Vectrax 7x12 band saw
    Miller spectrum 875
    30a spoolgun w/wc-24
    RCCS-14
    6061 is a real soft alloy in fact it's used as little as possible in aircraft. 2024 is the standard alloy for most airframe structures. If I were a betting man, I'd put my money on 7075. 7075 is used for aircraft landing gear structures.
      I guessed at 6061 as I read some aftermarket are now offering shafts made from 7075 as if it is a new application. I consider 6061 to be a harder alloy once treated to T6. To me soft is 3003 or 5052. Just wondering what rod to use to have the best chance at survival.
      Not welding it together just filling two small grooves in the middle of the tube and sanding smooth.
      MM250
      Trailblazer 250g
      22a feeder
      Lincoln ac/dc 225
      MM200 black face
      Miller spectrum 875
      RCCS-14
        I've machined both 6061 and 7075. 7075 is a much harder alloy to machine in my experience. With heating up aluminum to the melting point you lose hardness, which means that it should be heat treated afterwords. And that applies to any aluminum alloy. If it were my project, I wouldn't do anything to the shaft. It goes back to the good old saying that if it isn't broken, don't fix it.
          They are 6061...Bob
            Thanks for the replies. I am going to tig it with 4043. I'll probably do short sections trying to keep it as cool as possible. As far as if it ain't broke....... well it will break definitely if I don't do anything because it has two grooves worn into it about half the thickness of the tube. I'm not so much worried about it breaking while it's going but more so at launch, that's where the biggest shock is. It is mainly a drag car with occasional street trips. I am going to tell him I have no idea how it will hold up. Try a few easier launches before really putting the hammer down. It is what it is.
            MM250
            Trailblazer 250g
            22a feeder
            Lincoln ac/dc 225
            MM200 black face
            Miller spectrum 875
            RCCS-14
              Use 4943
              Its stronger
              Then try to bust it immediately by launching in a controlled environment. No surprises that way.
              Meanwhile find a spare. Or better yet fab a steel one.
              Miller 30-A Spoolgun
              Miller WC-115-A
              Miller Spectrum 300
                Update Didn't break yet. Here is the before and after plus time slip, see left lane.. Used 4043.
                Click image for larger version  Name:	0701081448.jpg Views:	1 Size:	30.8 KB ID:	591737
                Click image for larger version  Name:	downsized_0701081451.jpg Views:	1 Size:	21.2 KB ID:	591738
                MM250
                Trailblazer 250g
                22a feeder
                Lincoln ac/dc 225
                MM200 black face
                Miller spectrum 875
                RCCS-14
                  Click image for larger version  Name:	downsized_0703080919.jpg Views:	1 Size:	24.4 KB ID:	591741
                  Click image for larger version  Name:	downsized_0703080920 (002).jpg Views:	1 Size:	31.6 KB ID:	591742
                  Time slip from Friday night. Left lane.
                  Click image for larger version  Name:	IMG952018082495215658.jpg Views:	1 Size:	32.1 KB ID:	591744
                  MM250
                  Trailblazer 250g
                  22a feeder
                  Lincoln ac/dc 225
                  MM200 black face
                  Miller spectrum 875
                  RCCS-14
                    Nice...Bob
                      You need to pick on someone your own size...that was an ass whoopin you put on him.
                        It was the customer's, hot his.
                        HTP Pro Pulse 300 MIG
                        HTP ProPulse 200 MIG x2
                        HTP Microcut 875SC
